blueeyiz702
Member
With switcher zip,because I believe you must have rw for exposed to work? Could you let me kno please.thanks
Can I flash thru twrp with switcher zip in use for rw?Just flash xposed through twrp
Tried this, says permission denied..
I updated the OP. You have to run the command as root in order to use the terminal emulator option.
Assuming your device is already rooted, run thehow do u get to run as root?
command in the terminal and grant root access to terminal emulator before you run the
command.reboot disemmcwp
Assuming your device is already rooted, run thecommand in the terminal and grant root access to terminal emulator before you run thecommand.
