helpmeplease00
my samsung galaxy y wont open plz help
naistuck na po sya sa \\\\\\\\\\\\\\\" LOGO.JPG DRAW FAILED \\\\\\\\\\\\\\\"
Rooted my phone day before yesterday and bricked it yesterday.Steps How to Unbrick your galaxy y (SoftBrick)
1.Download Odin V1.85 on your Computer Odin3-v1.85.zip - 4shared.com - online file sharing and storage - download
2.Download S5360DDLA1 Android AdvicesGalaxy Y S5360 - Steps to Install Official Global Gingerbread DDLA1 2.3.6 Firmware
After you Install it Extract the Odin on your computer and Click Odin v1.85 and After you downloaded your original firmware, extract it also to your computer..
3.After that shut down your phone and put it on download mode![]()
4.Connect your Android Phone to your PC and Open Odin
5.And u will see a yellow box on the left side it means your phone is connected with the PC
6. Now click PIT and go to your extracted s5360 ddla1 and open that file and select totoro_0623.pit
7.same thing you do on Bootloader, PDA, Phone and CsC
8.now check if everything is done and press start ..
9.wait for the flashing to finish
10. If its finish do not unplugged the usb cable yet until rebooting is done
11. AND NOW..!! CONGRATSS!! YOU HAVE A NEW UNBRICKED PHONE
Click Thanks If I HELPED
Thank you so much for this post which brought back my Galaxy Y to life.
I had messed up with the .prop file which caused my phone to get stuck in boot loop at the reboot animation stage.
For anyone trying this, I'd say this works but be careful.
Also, in case it was not clear from this post:
PIT- totoro_0623.pit
Boot loader: DefaultCalDataWithBoot_S5360DDLA1_REV05.tar.md5
PDA: PDA_S5360DDLA1_REV05.tar.md5
Phone: MODEM_S5360DDLA1_REV05.tar.md5
CSC: GT-S5360-MULTI-CSC-ODDLA1.tar.md5
can u post a link for driver.i cant find 1Download samsung usb drivers![]()
hit thanks if i helped
