Ok so this my first time here so here's the problem i downloaded the V6supercharger(with the busy box and the app that read the V6SC) to play games faster smoother and it works a little,i live my phone in standby mode and then when i turn it in unstandby mode(sorry for my english) and only blackscreen i try turning on again and it wont work,so what i do is pull out the battery and put it in and it turn on,but i noticed that the boot is going continuesly(with samsung logo[BOOTLOOP])so i try this,what i dont understand is the "2.Download S5360DDLA1 Android AdvicesGalaxy Y S5360 - Steps to Install Official Global Gingerbread DDLA1 2.3.6 Firmware" i go to the link but i doesnt show any steps or link or something about the Gingerbread DDLA1 2.3.6 Firmware,and when i use the "HOME+POWER+VOLUME"+" it only shows clear cache,clear data(which i already do)reboot and the update via sd card thingy 3.After that shut down your phone and put it on download mode i already tried many times but the "DOWNLOAD MODE" wont appear..so can you help me??
i already have the odin,and back up the files in the comp,format the MC in "FAT32" put the files again,and my phone is only 2.3.5 gingerbread thingy ^_^
Oww BTW do you have any solution to remove/reduce the scratch of my Galaxy Y in the front screen,i already tried toothpaste(with my other phone)screen protector that doesnt even help!!,it gow scratch from our puppy labrador(just scratches in the front and chewed to the max in the backplate,so if there are no solution,how much does it cost to replace faceplate housing???
im from Philippines!!^_^
