Root How to Partition SD Card?
parkerskouson
I think im ready to try out all of the sense roms there are, but with the ones i have tried i get no more than 50mb of storage. How do i partition it? If recovery matters i have amon 2.3
Park what are you getting only 50 megs of? if you want to have multiple partitions on your sd card understand first that you can only have up to 4 partitions on a disk at one time second the card really isn't made for this and not to mention if the phones ability to handle it
Under rooting the gingerbread edition there is a guide for partitioning just click show and follow the instructions. Compleetly back up your card 1st tho, its realy simple. after you are done just move your files back to the card.
internal storage. but i dont think i will be able to do it cause i only have the stock sd card, which is class 2. but oh well.. i think im gonna buy a new one anywayi
while u guys are there... how do i set my avatar? i noticed both of u have one, and i want one :D
download an image. i forget what the actual size is, but it is pretty small. then go to the forums does not matter where, but there is a tab with user cp, premium, all albums........ select user cp on the left hand side there should be an edit avatar, select that and switch to any avatar you want.
