You have to search google for megalock.dll it's consider warez I believe so it can't be included. You will then use that megalock.dll to replace the one in the folder.
Mine doesn't say Boost anymore either, but works fine. Update profile and PRL. It is possible that you will need to run through activation again.
Did you do a factory data reset after you flashed it? It's under backup and reset. If not then do that then do the prl update and the update profile.
4G still hasnt come back on after factory reset, and prl&profile updates.
can someone please post a direct download link to the recovery firmware i looked in the place it says but there are 50 diffrent ones and when i click sprint there are like 3 diffrent ones i have boost mobile thank you
This is going to completely overwrite the contents of the phone. Updates are irrelevant.Just to confirm this works on the update that just came out. I basically downgraded back to V3 from V4. 4G LTE works as well. Everything works now I can root again![]()
Just letting people know this is what they have to do at the moment to get root back once you update.This is going to completely overwrite the contents of the phone. Updates are irrelevant.
Definitely you can run into problems. Images had to match on my HTC desire 601 when I'd flash a new RUUSometimes restore tools don't let you flash previous versions for obvious security reasons.
