mbwd
Member
This is a great guide. Thanks! Coupled with post #9 here, it should be all anyone needs -- even folks like me who get a little antsy with the recovery tool.
If it helps anyone:
1) don't forget to put the megalocks.dll in the same folder where you installed the LG Flash Tool (ex. [C:\LG\LGFlashTool]). If you forget, you will get an authentication error on the tool that will waste your time.
2) be careful when you download the LG drivers. The download page is full of spam program downloads that you definitely don't want and may accidentally select, thinking that it is the driver download. If you don't see the COM option in Device Manager, then you did not download the drivers.
If it helps anyone:
