Android Version: 2.2
Baseband Version: 2.15.00.07.28
Kernel Version: 2.6.32.15-gb7b01d1
htc-kernel@and18-2#1
Build Number: 3.21.605.1 CL231334 release-keys
Software Number: 3.21.605.1
ok i just looked at my rooted phone and everything above(software info) is what i have right now. It says i should get that when my phone is unrooted?, but i used unrevoked to root my phone and all the software info is the same? is something wrong?
If i've already rooted using Unrevoked3, do I need to re-flash using Unrevoked Forever and THEN download the S-On tool? or can i just use the S-On tool now?
Correct. And i've already done it. No need for unrevoked forever. I just used the S-On tool and followed the rest of your guide. Entire process didn't take more than 20 minutes. Thank you!Not sure I understand what you're trying to end up with as your final goal. You wanting to unroot and go from s-off back to s-on?
You probably never loaded a custom Rom or kernel so the specs would be the same. If superuser is gone, then it worked and you are on 2.2 and unrooted.
follow this guide to unroot your phone no matter if you loaded a custom rom or not. Process is still the same.
I tried this yesterday...I thought everything went OK because the phone booted back up. now the touch screen is not responding and I have a triangle above the signal bars which means I am roaming...Any Ideas?
ok, so i returned back to stock 2.2, but forgot to turn s-on. what do i do now to get s-on? can i get OTA updates even though S-off? I don't have superuser in my app drawer
i have a little blinking green light at the top does and a black screen does that mean its working? (stupid question i know)
I have a rooted Incredible running Uncommon Sense 1.1 and the Nov. update wasn't installing, so I have decided to go back to factory and re-run unrevoked.
I have tried all the steps in this guide. I have used a 2gb and 512mb microsd cards...both have been formatted extensively and I am receiving the same error as others. When the phone reboots, it fails to install the zip
I am currently looking for another way of getting back to factory defaults. Any assistance would be greatly appreciated.
Well oddly enough after formatting the 512mb card a few (more) times and downloading the stock rom from an alternate link I was able to get it to install. I was having the same issues as several others:
SD Checking
Loading...[PB31DIAG.zip]
No image!
Loading...[PB31DIAG.nbh]
No image or wrong image!
Loading...[PB31IMG.zip]
No image!
Loading...[PB31IMG.nbh]
Updated, rooted (unrEVOked 3.22) and back to Uncommon Sense v1.1, so far so good. I really do appreciate the replies and your genuine concern.
Thanks again.
