Whyzor
Android Expert
This is a simplified guide for those new to rooting & flashing a custom ROM on the Optimus V. No need to type complex commands that are hard to follow and prone to mistakes. Basically there are 3 main steps: Root, Install custom recovery, & flash custom ROM.
Windows Drivers for the Optimus V (Optional but suggested):
http://www.lg-phones.org/wp-content/uploads/LG-Optimus-V.zip
Rooting
Rooting is the process of gaining administrative rights to the phone so one can do customizations that aren't normally allowed. Root by itself doesn't do anything cool, unless there's an app that needs it. The fancy stuff comes from custom ROMs. Just remember Virgin Mobile Activation only works on Froyo ROMs, so do it before going to Gingerbread. The easiest way to root nowadays is to use GingerBreak. It can be found here:
[26.04.2011][v1.2] GingerBreak APK (root for GingerBread) - xda-developers
Instruction Steps:
1. Turn on USB Debugging (Settings - Applications - Development)
2. Copy the GingerBreak.apk to a /sdcard dir, then using a 'file manager' app (search for one in Android Market) install it like a regular app.
3. It can take up to 10 minutes, and will reboot automatically when complete (rooted), if attempt fails, reboot manually & run it again.
Install custom recovery image
The recovery image is an alternative bootup instead of normal Android Operating System. It allows low-level operations such as backup/restore a ROM, wipe partitions, and flash ROMs.
4. Download and copy the recovery image VM670NH_recovery.img (works with new & old OV screens) onto your /sdcard.
5. Install the Flash Image GUI app (save the .apk to a /sdcard directory, then open it with file manager). Run the app & select 'Recovery Image' option with the file above.
Flash Custom ROM
http://androidforums.com/optimus-v-...wip-backside-rom-cm7-green-machine-theme.html
6. Copy the unextracted ROM .zip that you wish to install to the /sdcard dir. Also if installing a CyanogenMod Gingerbread ROM, the unextracted gapps.zip version 20110828, also needs to be placed in the same dir to flash right after the ROM .zip.
7. Boot into Clockworkmod recovery mode (From powered off state, hold vol-down, home, and power button until the LG logo appears).
8. FIRST, BACKUP ORIGINAL ROM! Don't continue until this is successful. Use vol-up/down, camera, & back keys to navigate in recovery.
9. Wipe Data/Factory Reset, wipe cache partition. Under Advanced submenu, wipe dalvik-cache. Then uner Mounts & Storage submenu, format all partitions EXCEPT /sdcard.
10. Install the custom ROM.zip from sdcard and gapps.zip too if going to a CyanogenMod ROM
11. Reboot and enjoy the new ROM, the first boot takes longer than usual, also some problems may disappear after rebooting.
NOTES:
- NEVER use Android Settings 'Factory Reset' from now on, only do factory reset & wipes from within recovery mode. Most ROMs should have this option removed from the Android settings.
- Some newer Optimus V screens hardware changed, see link: [FIX]Black screen with custom recovery and custom roms (BobZHome's IHO recovery from the Wiki binary -> recovery page also works with newer screens.)
- If restoring a backed up ROM in CWM recovery gives 'MD5 mismatch' error (likely caused by renaming a ROM backup). Try this fix:
# cd /sdcard/clockworkmod/backup/<name_of_backup>
# rm nandroid.md5
# md5sum *img > nandroid.md5
- If you ever want to restore to original stock ROM (ONLY on OV's with older screen), with original recovery and UNrooted:
How to restore your Optimus V to almost original condition - Prepaid Android
Rooting
Instruction Steps:
Flash Custom ROM
NOTES:
# rm nandroid.md5
