P.S. Make sure you do not uninstall mail@metro as it will cause problems.burner, i deleted mainly what you have on your lists and have had no problems either but then again i only froze them, i only deleted uno and the free games.
also question for josey, is there a reason you recomend temp root vs. perm root for metro? i have metro, it was my first time rooting but i did permanent and all seems fine should i change that?
First make sure you have usb debugging enabled in application development settings. Install z4root by Googling it and clicking in first link. After opening, if you have METRO, choose temporary root. Then install titanium backup from market.P.S. Make sure you do not uninstall mail@metro as it will cause problems.
Joser are you online? I just tried to d/ld z4root from the xda-developer site and the install was unsuccessful. Got this message:
<Unknown>
forum.xda-developers.com
Cannot download. The content is not supported on this phone.
I have USB debugging on. Also, have it set to accept unknown apps etc.
Any ideas?
hi,
I have a Huawei Ascend for metro and i want to get rid of the useless apps that are on the phone and i have read a few post and i did what some people said and i dont think i did it right and i download the z4root and it didnt ask me to temp root or permeant root and i dont know what to do but if someone can help me out.
Thanks
Well i download z4root and im lost from here on what do to but i did what somepeople said on forums and the i click on the z4root and then click the root button and it shuts of and i dont think its working right or im just doing something wrong im not sure
