Root HTC Evo Rooted SD Card Blank Help
RBK1024
My HTC Evo 4G Is Rooted But My SD Card Has No Rom On It And It Wont Go Past The White Screen HTC Evo 4G It Will Not Go To Into Usb Link Mode Into My Computer. How Can I Get A Rom Back Into My SD Card ? Recovery Mode Says Clockworkmod Has No Files. Please Help !
P.s. Wat Did I Do Wrong ?
Welcome to the forums!!!!!!!!!!!!!!!!!!!:D:D:D:D:D:D:D:D
Seeing that you are rooted I moved you to the 'All Things Root Section'
Have you tried using a usb card reader and moving a rom onto the card that way?
After moving the rom to the sd card, boot to recovery wipe everything, data/factory reset, cache partition, go to advanced and wipe dalvik cache,
then flash the rom of your choice
also since you have clockwork mod recovery yu can still access your sd card. go into recovery and select "mounts and storage" and then "mount usb storage". make sure that the usb cord is connected from phone to computer. you should see the window pop up with your sd cards content. you could just move your rom on to the card that way.
