Wow.
That is amazing to hear, they must've tweaked something between the Desire and Inspire.
i told you they did
Wow.
i told you they did![]()
Totally missed that. Any idea of what? Power supply unit maybe? Seems like it's become a really efficient device (possibly why it took so long to get it over here?).
SECOND GENERATION:
The MSM8x55 chipset platform consists of the MSM8255™ and MSM8655™ and features a newly designed and optimized multimedia sub-system over previous Snapdragon generations.
- Scorpion 1 GHz CPU
- Integrated 3G mobile broadband connectivity
- MSM8255 support for HSPA+ networks – up to14 Mbps downloads and 5.76 Mbps uploads
- MSM8655 support for HSPA+ networks – up to 14.4 Mbps downloads and 5.76 Mbps uploads – as well as CDMA2000 1X, 1xEV-DO Rel 0/A/B
- Low-power 45nm process technology for higher integration and performance
- High-definition (720p) video recording and playback up to 30 frames per second
High-performance GPU - up to 41M triangles/sec and 245M 3D pixels/se with dedicated 2D Open VG graphics hardware
- Multiple video codecs: (MPEG-4, MPEG-2, H.264, H.263, VC-1, DivX, DivX 3.11, Sorenson Spark, On2 VP6)
High-resolution up to XGA (1024x768) display support
12-megapixel camera support
Built-in eighth-generation gps engine with Standalone-GPS and Assisted-GPS modes
Support for Wi-Fi
Wait, you guys do know the basics of microchip architecture right?
The original snapdragon was built on a 65nm manufacturing process. The second generation snap dragon runs on a .45nm manufacturing process.
When you shrink the die like that it results in SIGNIFICANTLY reduced power consumption with the same architecture at the same mhz..at significantly less heat production. Added to that each silicon wafer produces that many MORE chips per run resulting in cheaper manufacturing costs. The result is that you could pop on a larger batter and easily run a 45nm snap dragon at 1.2+ghz without it over heating (safely)..but running it at 1ghz = much less power consumption and cooler temperatures (in addition to cost).
I am soooo sorry. (not being sarcastic). I really thought everyone already understood this about the Inspire and why the 1230 battery was selected or id have brought it up sooner.
Here are some numbers:
I understand the idea of the difference in microchip design, but this same chip is in the Desire HD and the reviews for battery life are a lot more favorable for the Inspire than they are for the Desire, and they are essentially the same device. Some kind of tweak must have been made somewhere to better manage the battery life.
Dude, how many times in how many threads linking how many reviews will it take? I dont mean to be rude, but everyone who has used the phone for more than a day says it lasts through the day just fine. everyone who is making an issue or speculating on the battery has never used it for a whole day. Rename this thread to "Battery non-issue"
From what I have gathered, which is the case for any Android phone, it depends on your usage. For the DHD, most users seem to be happy with the battery life they are getting, but some are complaining.
If you are a heavy user (alot of 3G, syncing with calenders/e-mail, streaming, surfing, etc), then you might have to consider carrying around a backup battery (if you don't want to buy a backup battery, then at the very least, keep a car charger in your car and the desk charger in your briefcase at all times).
I agree but I think the issue in this title which it is referring to is the size of the battery (1250mAh) which is smaller than pretty much all other high end phones on the market (including its T-Mobile brother).
Personally, I think the size of a battery is misleading. Good power management, and efficient programming do a world of good towards battery consumption. HTC is really starting to nail it!
What's amazing to me about those that complain about battery life (and, yes, it's not this way for everyone) is that they do some insane use of their phones in a day, and still aren't satisfied. Movie watching on the train/bus, pandora listening at work, texting and IMing all day long, talking on the phone, downloading music and large files, etc.... it's never enough, for some people just can't be satisfied in todays world. Not saying that's anyone around here, but it does happen.
Wow...that just might be the dumbest thing I read all day.
You may like under-utilizing your phone, but giving anyone grief for wanting to use their phone however they see fit is just wrong.
I really don't understand how some of you are cool with putting up with small battery capacity and/or battery life.
You could also buy an additional battery if you know you won't be near a power source (say traveling somewhere) and switch to the 2nd battery if it's necessary. Not sure how much an extra 1250 mAH battery would cost, but at least this will give you peace of mind.
