hello, everyone
I used my HTC One for 8 and half hours, and I still have 50% left. I checked my phone once or twice in an hour, and played with it for 5-10 each time. Does my battery looks fine?
Thank you!!!
The answer depends on many variables. For my usage, 40-90 minutes screen on time (5-10 minutes/hour), 8.5 hours standby and 50% battery left would be worse than I expect.
But this depends on many variables, e.g.
* Is this your first charge cycle? Rechargeable batteries improve their performance over the first few charges, so you expect the first time through to be worse than normal.
* What's your signal like? Weak signal, searching for signal, swapping between bands (e.g. 2G/3G) all result in rapid battery drain. Similarly, WiFi uses less power than cellular data, but if you leave it constantly on and scanning for hotspots that will use power too.
* What are you doing when you have the phone on? Games will use a lot of power, ebook reading very little, other activities inbetween.
* How's your screen brightness? The screen is a big battery user, so if you have brightness set to full all of the time you will use a lot more power than if you use automatic or adjust it manually.
* What are you doing when you have the screen off? If you have it constantly polling for updates to location, weather, social networks etc it will run the battery down faster than if you have these things off or set to update less frequently.
* What else are you running? Task Killers or "Memory Optimisers" (another name for the same thing) will run your battery down faster (which is the opposite of what they claim).
I usually reckon to get about 4.5-5 hours screen-on if that usage is mainly browsing. eBook reading could give double that (seriously), and gaming would give less. And if I just left it in my pocket most of the time I'd get several days standby. However, I'm usually in a strong signal area, I don't have automatic weather updates etc, have no social media apps running, disable location reporting and turn mobile data on when I want to use it rather than leaving on full-time (though often leave WiFi on when in the office or at home), and keep the brightness at "comfortable" rather than "full". I don't use the power saver mode though. So if your usage is different from mine, I'd expect your battery life to be different too.
It depends a lot on usage. The phone looks like it's spending more time screen on than you reported in your first post, and as Luna says, WiFi on full time may not be optimal. I gave a longer reply in the other thread recently.
