cool! thanks for the output,its pretty much wat i expected to see.i hated to keep saying supercid without knowing for sure,tho.
im really wondering if theyll find a way to disable the system WP,or if were really stuck with that forever. im sure we can adapt... for those that like to chagne certain things,im sure you could whip up a recovery file with a new build.prop or whatver,containg your mods. or if flashing a custom rom,you could just open up the rom and modify its files before flashing.
i really hope devs just start scripting roms to install the boot image. that way you can
fastboot boot recovery and then just flash the roms normally. otherwise,youll need to deal with installing the boot image seperately every time you flash the rom. its a huge PITA. for the rezound, devs came up with all sorts of dumb ways to "auto install" the boot image,wich,IMO,just made it more complicated and confusing.
we can only modify system,boot,and recovery. another thing thats different about this phone is with s-on,PxxxIMG file flashing is a PITA,as the main version number onthe android info document is now important,with s-on. to use these types of files youll need to modify the main version on the text document to that or higher than your current,or the file will not flash,causing much fustration
further,you cant flash PxxxIMG files from the internal sd card,so flashing these types of files HAS to be done from fastboot,via RUU mode and the
fastboot flash zip command.
the 100% easiest thing to do is just
fastboot flash new recoveries and boot images,and not even mess with PxxxIMG files.
if you need to run an official ruu,you need to relock to run anything signed by htc and containing images other than boot/system/recovery. easier way to run them,is to just run the .exe. rom.zip can be extracted and run from fastboot,or in a pinch,via an external sd card in a card adapter and OTG cable,assuming this phone to work like the one X.
hang onto your original unlock token,you can use it to re-unlock if you need to lock for some reason,
just a couple things off the top of my head,from my s-on flashing experiences. alot is different than with an s-off htc or unlocked gnex. but im sure youll pick up on it pretty quick,youll just need to learn some new ways to skin the cat
these bad boys are starting to pop up allready,but folks are still wanting $500+ for em
so ill have to wait a bit,and keep fingers crossed an OTA doesnt wipe out the temp root method!
