Left side icon is that of the battery saver application mostly...
Hey i was just kidding yaar i know that profession and passion are different in there own ways and development is your passion. DOC can we have the Screenshots of the new things MODDED and also how much more work is left and when will this ROM makes it presence and go live for our handsets. Please let us know to keep us calm as many including me are waiting for a stable ROM with good features and haan DOC provide the ROM with the basic package and that to Odexed version to keep the system running smooth and also to make the boot timing less.
iam having some little problem with this rom
1. superuser is not responding to any root app
2. front camera 90* rotationpoblem
3.volum is very low
no sir i can fix 90* rotation by my self but plz do something for volume its really very low
there no launcher in this rom
Sir plz do something for supruser peoblem other wise ur rom is so gud.
Sir help map is showing incorrect location I also got the same poblem in ur oppo rom. But when I use other rom there is no poblem
thanks bro..u solve my problemRibhi I got it what are u trying to say slide it from down to up side then.u can se the launcher I hope I was able to help
Little disappointed bro...
pros:
1.very fast
2.also stable
3.160MB internal free
4.Lewa themes can be downloaded
5.Chrome browser (I like it)
Cons:
1.Camera app has much less options
2.It should have Super SU instead of Superuser
3.apps cant sorted
Battery backup is looking good after-all it uses less RAM
BTW it was nice work.I appreciate it
sir plz can u change the battery icon and wifi icon on status bar.
Camera is not a big issue... I can solve ur option problem within 1 minute..
U can install SuperSU through Play Store,,
I cant understand ur 3 Cons.
