Shrikant716
provide the ota updates for the rom .
that will be good for downloads as per requests.
Camera is not a big issue... I can solve ur option problem within 1 minute..
U can install SuperSU through Play Store,,
I cant understand ur 3 Cons.
This is Camera FIX:
fix for front camera and more camera options ...download this file and put it in system/lib folder by root explorer and give permission to rw-r-r- and reboot..... thats it....
https://adf.ly/RC33J
However I tried some other camera fixes So now reinstalling ROM & try again for camera fix...
For those who r facing superuser access Just enable USB debugging ....
Try to replace boot.imgbro i tried for superuser access as you said nothings happening
hello sir ..your rom is quite good and fast ..but cannot find any app to use my phone flash as torch and also cant find adobe flash player version which can be installed i was using it previously both on sagarwrap rom ics version..so it is known that this phone supports both the app adobe flash palyer and ..phone can be used as torch.......and also does this rom support skype??..it was not running on that rom..but this rom also has problem with camera..please give an easy way to install camera fix..and kudos for your great work..the problem with superuser have been sloved..please look into that as falsh of phone as light is very importnat for me..
USB Debugging should be enabled in order to work Super User !!!
Also try to wipe all things & reinstall ROM
@GAUTAM, Sir U have developed such a wonderfullll ROM, most of the A75 Users have started using it also...i also want to comment on it...but sorry to say that m not in the list coz I already requested to upload it on 4shared... Mediafire is blocked here... Dats y... Pls see if u can change my sad face a big SMIle...its a request..
some how i was able to do it..yesterday only but thanks...i mean superuser thing and flash palyer is also being supported..this is one of the best rom with a excellent battery backup...now only one concern for me is how can i use my camera flash as torch ..none of the application from market are doing it can anyone help..and any upadte about camera fix
nice to c that all problems r going to solved though I have no issues except camera .... and that too solved by using new libcameracustom.so file (link given above).
I have done lots of efforts to make this ROM... n my main concern was with speed and battery..also it contains features of different ROM's..
and now onwards I am shifted all my development work to my blog itself.... i will answere all queries there only... n trying to solve camera problem.
@amol - thanks it worked ..flash working nowHi Tanvi, Hope this app will help u for ur LED need... go to the link--- Lite LED (Flashlight Widget) 1.1 - APKTOP
