amolmendhe
Member
Hey Gautam Sir... Thank you... Thank you Very much for uploading this ROM on 4shared... Downloading Now... Thank u 1ce again... u rock man... Keep It up ... (A BIG SMILE)
Whoooo.... Sir Ur ROM is Wonderfullllll ... As i m a music liver so u have taken most care of it in ur ROM... Radio FM is working flawlessly awsome... No signal fluctuation in it... In all the previous ROM's FM was not playing properly.. some signal problem was there... i was thinking it was the problem of the FONE, but ur ROM proved me wrong.. ! more wondefull thing, that we can lower down the Sound even if the screen is locked.... Thank you sir thank u vary much... Hats off for the apps u used for enhancing the Sound Quality... I only got bug while opening the dolby mobile, its not opening... Why??
bro dolby mobile need superuser access ...............if ur superuser app is working then u can use this option..................
sir will u plzzz remove adfl links from ur blog bcz i cant see ur blog bcz of this...............
Sir I used http but nothing hapen plz remove adfly link from ur blog
Sir, In the Default music player, when i check the equalizer button, FC issue is coming... and all music player force closes... Also suggest which app to b used to make the Memory auto-free??? Since the app u have given to free memory does not work on auto mode...
I have been struggling for superuser issue for last few days. Solved.. I great tip!!!!!!!!!!!!!!
installation aborted status 0. I think problem is in meta-inf folder.could u make aroma installer for this plz help me soon
