Root I need help fast >.<
It just happend. It was on then it freezed...so i took the battery out and then it didnt want to restart or anything. The phn is rooted and is running Mikg ROM sence.
Pull the battery again, and then replace the battery and hold the volume down button while turning the device on. The "HBOOT" screen should come up. Choose "RECOVERY" from the menu, and once in recovery, choose "Wipe" and select CACHE, and then DALVIK-CACHE. Then try rebooting and see what happens. It may take a little longer than usual to boot up.
What recovery version are you using?
Nothing has happend its all the same :( it doesnt wanna load up :( did it brick?
Yeah. It goes itno HBOOT and then recovery i wipe cashe and delvik...then it just stays again in the HTC.
In that case, you should probably just reflash the ROM, unfortunately. That happens sometimes.
I think there's a version posted around here that won't completely wipe your device, but personally I think you need to wipe everything but SD card and start over. That should ensure your device will boot up.
Okay thanks ill do that tthen ill tell you what happends.
You can get into recovery so your good. Try to just reisntall the ROM you will need to use the Upgrade to reinstall the rom not the full one as it wipes everything
just remember that as long as you have recovery, you are pretty much all good.
glad it worked for you. i would make a nandroid backup if you have not already. you can always try and restore one if anything else happens.
