ok it was fine after i updated some apps
the phone stared turning on and off
so i made a factory reset it was working fine
then i try to updated the software
now is not working any more
is not pasing from the white screen
i dont know that rom it had from the begin
but i been tring to put this ones
Deck_reloaded_357_7zip
sos_x-n_2.0.9.4.zip
the express 3.6.1.zip
the phone take theme fine but when is finish
say asser failed: wrtite_raw_imaging("/tmp/boot.img","boot")
istaller status :7
this what is on my phone
supersonic evt3 ship s-off
hboot-2.02.0000
i have clockworkmode recovery v2.5.0.1
the phone is not recognize the zip file
i dont if is something with the sd card because is not the one with the Root file
i just add a new root file on the sd card and i putted the zips there
and i do not know what you actually mean here. can you explain further?is any way to take the root of the phone and make it work
with out the root
i tryed to put amon ra 2.3 on the phone but is not doing anything
i follow the instruction that you give and nothing happen
and i want to know if is any way to take off the root from the phone
or some thing i need it working
is working but whene i try to do the nandroid backup
it say
SOMETHING WENT WRONG PLEASE CHECK THE RECOVERY LOG!
and what rom can i put on it
