The cell phone companies won't use it because all the crapware they get paid to put on there has been taken off, which makes it work better.What are the advantages with this Icarus over 2.2 and if so how is it better!
If the smart phones and there makers where impressed with it they would use it on the cell phones already for the public?
Just want to know what is all the interest in a program outside the normal use of the cell companies regular use on cell phones.
Also Icarus comes rooted. I really don't see companies using that sort of idea for mass marketing. They actually try to prevent people from rooting in most cases.The cell phone companies won't use it because all the crapware they get paid to put on there has been taken off, which makes it work better.
I heard Icarus are faster , less lag
2.2 got bug like mms
so like say if i install Icarus
I wont be able to download any app
on the Market
Requires 2.2 ?
Nope. No 2.2 apps.
If you use setcpu now it won't work with 2.2 either. If you are going to flash just for a couple 2.2 apps you may want to check your most commonly used apps for 2.2 compatibility.
So I should not bother with my 2.2 system on it your saying then?
I'm biased towards icarus because I used it for a bit. Trying out 2.2 starting today.
Looked like you needed your first "thanks"![]()
I had Icarus but now I have the 2.2 froyo on my ascend and it's much better. They both work well, but the 2.2 froyo is just awesome! I won't go back.
2.2 is running pretty good for me. I love speaking into the keyboard and printing out my texts for me. All my apps seem to work okay. Internet surfing is blazing fast. I don't like that picture messaging doesn't work. Icarus is just a great rom, 2.2 is good but needs some work. bluetooth does not work because the update is not for our phones either. Usb mounting also does not work
I had Icarus but now I have the 2.2 froyo on my ascend and it's much better. They both work well, but the 2.2 froyo is just awesome! Until the uim error
Internet through 1x is the same for me. Wifi seems faster though.
I was really mad that bluetooth doesn't work. Now I'm back to wired headphones.
The stock keyboard on the stock rom has the same voice to text feature.
Gonna give it use testing today. See what the battery life is like.
