Root Icon packs help
First I wanna say sorry if this is the wrong page for my problem. So I found icons on the internet and I put them on my phone. Using Desktop visualizer I am able to switch out the icons and create a shortcut but I have the old icons in my app drawer anyway I can get rid of that one and put the new one in thanks in advance.
I dont use that app but I have used FolderOrganizer, which is similar in that I can change the home screen icons for my apps.
Now, it doesn't change the app drawer icons, and that's the way it is with FolderOrganizer.
Perhaps it is the same with DesktopVisualizer.:)
I would assume it's like to a shortcut icon(with the arrow) on a pc's desktop and it only points to the program. When you look at the apps on your phone they are the actual program and can't be changed.
this is partly true the only way to change the icons in the app drawer would be to change the icons for each individual app. Not only can this be very tedious work the first update will wipe out your icons for the apps that were updated. This really makes it an undesirable task to take on. My recommendation is to leave them as is.
