Root ICS Messaging (Question)
AndroidAdmire
Hi all. I have a question, if i were to replace the stock metro PCS messaging app with the ICS Messaging from the market will it still work. Like if i flash it as the primary messaging app. I want to use that instead of the stock app. Thanks!
-AndroidAdmire
Nothing from ICS as far I know will work on GB. I tried using the gallery once and even that wouldnt work.
I used the ICS messenger app as well as the stock one together. Dunno about uninstalling the stock one....
ahhh. In that case you would probably be correct. Most ICS or Jellybean apps I try to use give me a parsing error and wont even display an icon in a file explorer
yup, same thing happens to me.
That ICS camera in the market is so garbage its not even funny. it's pathetic to even call it a camera. The flash doesnt flash correctly so pictures look F'ed up.
ICS gallery is also garbage. Ill put pictures on my SD with OTHER pictures that are already loaded and they wont load for days or even weeks. I had to get rid of it, just awful.
And SMS, I use GOSMS mainly because I can set the vibrate pulse to vibrate to a length that I define. I wish the stock app did that.
Fuzzy I mostly agree with your assessments except for some reason i kind of like the ICS camera app
I just dont like the limited settings and the flash sucks. The timing is off. If you take a close up picture with the flash on and compare against stock, you will see.
Plus the stock has 30fps now :D
Do you think someone could port the jb camera app to LG esteem? I love that camera app. Its Uh-mazing!
As far as I know nothing 4.0 and up can be ported. Ported and be fully working. Im sure something could be dirty ported and be buggy as hell at the same time.
