Help I'm having a Wi-Fi problem
m-cman
I'm having a different Wi-Fi problem. It turns off and won't come back on no matter how I try to turn it on. Have to turn the phone off then back on to be able to get Wi-Fi to work. Have tried with the Connection Optimizer on and off. No difference. Phone is completely stock. :confused:
I have not seen this problem before. Is the phone rooted? Have you taken the latest March OTA update?
Phone is completely stock. Do have the latest update though. Also, a couple times I had to re-enter my password as though the phone forgot my Wi-Fi setup. Not every time though. Never happened with my LG OPV. :confused:
Oops, I should have known you took the OTA since you have the connection optimizer. :o I don't have many ideas to troubleshoot this one.
Does this happen only on your home router or everywhere?
If only at home, restart router or look through router settings??
Did this problem start right after the OTA?
Have you tried removing the wifi connection and re-connect to it?
As a last resort a factory reset may help fix your problems but you would lose all your data :(
I will also ask around to see if anyone else has any ideas :)
Haven't tried anywhere but home. My PC uses the same router and is ok. My LG OPV also used the same router and was fine. Just activated this phone on April 7.
Did the OTA right after activating so don't know if it had effect. Wanted to be sure I didn't get any of the original problems plaguing the EVO V.
Not removing but lost the connection twice and had to re-enter the password. Will try this next time it happens. Turning the phone off then back on seems to fix it.
Thanks for the help...:)
But for how long does it last until it turns itsself off again. Personally if you have only had the phone a week, I would just perform a factory reset and start clean. Will probably permanently fix the issue :)
Just a thought. Worth a try. Even though it seems like your router is solid, how about going through the reset routine on it once. Powering it off for a bit and then letting it come back up?
Is the router a b/g or n? Maybe you can change a setting in it that would make it more phone friendly, if that is selectable.
