whewstoosae
Thank you sir for the app, it works great!
There's already an LED flashlight app for the Evo called LED Light. It's free, and doesn't require root.
I would use Led Desire Light. You can set how brightly you want it to light up when you set the widget. And if you actually go into the program you can use SOS and even flash words or sentences in Morse code. I found that Led Light is not bright enough.
@ vincent, I hope you don't mean the LED's will die or burn out. They are extremely efficient and burning them out would be unlikely.
I use LED Desire its pretty cool you can even type in text and it will blink out the morse code for you.
I know its probably not best to use your phone as a flashlight for long peroids of time, but how will this fry the lEDs. Aren't LEDs in flashlights all the time?
