Actually, since the Incredible uses an AMOLED screen, it is an LED flashlight...Awesome led flashlight...
Actually, since the Incredible uses an AMOLED screen, it is an LED flashlight...![]()
Any chance of a widget set to high (or configurable). Easily the best flashlight app for the incredible - this is for incredilight
As well, the screen won't timeout and shut off the light.... Hey the App doesn't actually turn on the notification LED, it turns on the Camera flash LED. For those of you that got the update this week, it no longer requires root if you have Froyo... Not that any of you would have that yet...As well, the screen won't timeout and shut off the light....
I'm also working on updating the icons and enable to select from a set or two of them for the Widget.
Thanks for all of you that make suggestions...
LEDs used in flashlights have large heat-sinks; the goods ones are usually coupled to the case of the unit (where the case is metal at least).
I don't know what heat-sinking is used in the Evo 4G for the flash LEDs. Sometimes its just the solder pads that mount the LED. If that is the case, then running it for more than a few seconds at a time will kill it very quickly.
Regardless though, if you saturate the heat-sink, the LED will die. The question is, how long will it take to saturate, or is it sufficiently well cooled that you can't (highly highly doubtful).
Are you using network access to check if the phone is rooted somehow? The update that came out for Incredilight this week mentioned it required network permissions.
For you non-rooted users, the upcoming 2.2 Froyo update has a built-in HTC Flashlight app (at least the leaked version does).
You guessed wrong. It has three intensities, auto-flash, and SOS.i'm guessing the htc version doesn't give you the ability to go high, medium, or low intensity on the LED though...
I have a 6 D-cell maglite ... yeah, it's awesome.Mag-Lite ST3D016 3-D Cell LED Flashlight
High-strength aluminum alloy case
Corrosion resistance and durability
Water and shock resistant
Adjustable spot-to-flood beam
High-grade rubber seals
Design balanced optics and power
Spare lamp safely secured inside the tailcap
Home - Mag-Lite ST3D016 3-D Cell LED Flashlight
funny my son came in a few hours ago with his X's LEDs blazing--just got the app from the market. another inc disappointment.
