Root Installing Liberty Themes From Toolbox
irmac
I go into the Liberty Toolbox, navigate to the theme I want, click it, it goes through the Downloading/Installing screen for a while then it reboots, looks like it's installing a theme, and then I have to reboot.
The problem is after all this, nothing looks different. I have tried many of the Toolbox themes but none seem to change anything. What am I doing wrong?
Thanks,
iRMac
Another question a little off the OP, is it possible to get the blur status update widget back on Liberty?
1) You're probably not downloading the full file.
2) No. If you want more blur, try the new TranQ 3.7.0. It has the ability to add much more blur than Liberty, Fission, etc.
You should see if the phone is rebooting into Clockwork Recovery like it should.
If you don't have the DroidX bootstrapper and ROM Manager/Clockwork Recovery installed and configured, Liberty won't be able to properly reboot and flash the files you are trying to install.
-Mike
Mine is doing the same thing. It will start to download, boot into recovery and it will say install aborted. So I am not sure what is going on with this.
my toolbox has some trouble downloading and installing themes seems to never actually download...so i just download them to my SD card using the browser...move them to the right folder...THEN go install from the toolbox...works like a charm every time...
