Lordvincent 90
I have tried every tip i can find. Anyone know a working version. (And install method)
I tried the one that Came stock. Beta (newest), djdarkknight versions. And manual install for each version (apk & lib) .
Stock. Installs manually no prob, even opens ... but when. U try to swype a word it gives incompatability. Warning... all other versions mentioned. Just fc (and show up as a 3rd party keyboard)
I'm becoming very frustrated as my fat fingers are no match for the. 'Vail s small screen
(I know there. Is a similar. Thread in main prevail page... just figured atr section was better place for it considering. Root is very super basic request for cm7.
If someone could post compatable apk & lib versions it would be much appreciated
Thanks in advance for any help
I travel for work, and have no lap top. I have had no access to my files. I had even formatted my partitions and reinstalled everything with no luck. But as usual hail Odin. Thank you everyone for your patience. I have been here lurking and learning since shortly after shabby .6 the Prevail is my first smart phone and the initial root was done by someone else with no explanation of y. Since I have modded 5 other prevails. 2 motorola triumphs. A sidekick, and a optimus m that was 2.2.2 I have truly learned so much from everyone here and an just now beginning to feel comfortable adding any input. Thank you so much everyone who has contributed to the development of this phone. I recently compared mine to one that was stock and I could hardly tell they were the same phone. You are the reason that Android is even worth having. Keep up the good work!
See if it was the same way i did it...
