Hawker
Android Expert
I'm all up an running to exactly how I want my phone to be.
Here are the issues I've noticed so far
1. wifi only works with static IP address, DHCP fails to connect. If you have never done this before, when setting up the wizard and entering wifi, you need to show the advanced options
then scroll down and change dhcp to static
then actually enter an ip address in the box (dont just leave the one that it shows or connect wont become enabled) You're better off just entering the one that it puts in (eg. 192.168.1.100 or something)
2. There are some UI issues in the clock app when ADDING alarms. Sometimes hangs, and the repeat days text disappear when the checkbox is ticked/unticked. Does not seem to happen after the alarm has been added.
3. The Dark Theme toggle in the stock SMS app does not work. SMS app is always dark regardless.
4. When picking a ringotone I get a strange entry at postion 2: Default ringtone (%1$s)
I'm now 100% up and running back to normal and that's all I've found.
Excellent work Dan!
:thumbup:
By the way, I love the new dialler in this, with the letter initial icons for contact with no photo. VERY nice
I usually like dark themed diallers, but I love this light one
Excellent work Dan!
:thumbup:
