IRC Channel
Stickied!!! :eek: :D :p ;) :)
Good luck guys!
Please note the new channel name! This channel serves as a destination for all devices served by Shabbypenguin and I.
Please note the channel has changed servers.
Thanks for the Info. Soooooo..... what are the chances of us seeing a ROM from you for the Connect? As you can see there is not much movement going on for this phone or at least not much since I got it about 2 weeks or so ago :D. Either way, thanks for the info and for all that you do.
going to go thru metro update and wanted to know if any modders needed anything first and maybe brainstorm my plan.
connect #1
rooted
sw v=ms840zv8
connect #2
stock
sw v=ms840zva
plan
activate #2
dl metro software update
root & play
get tether working
Any ideas?
