Since the Screen on the SGS-2 is a Gorilla Glass (is it a Gorilla Glass ?) which makes it Scratch proof, is a Scratch Guard/ Screen Guard really required in SGS-2 ? I know some of you would say it is better to have it ? But my question is keeping aside having it is better factor, is it really required ? Like the Iphone 4/4S Screen is also a Gorilla Glass display it absolutely doesn't require any protection what so ever !!
If I use it properly keep it all the time in the case that comes along with it, remove from it only when I am using it, taking such a proper care of it will it still require me to put a Scratch Guard on it. Ideally I don
so they need a screen protector, but if ur usage will be in normal circumstances, u definitely dont need one. ive been using mine for 6 months now, and im not the most careful person, n there's not a single visible mark on my screen.
) and a few more scuffs and scrapes will only add character and make it even more "you".
