Ok I read the rooting for dummies and it seems simple. My understanding is that if I follow those instructions I won't be able to flash roms but instead its a basic root with super permissions, am I right? Because I think that is what I'm looking for as of right now. I will keep reading but I have a few questions. If I do the dummie root method will I still be able to use 4g?
that and hotspot were my reasons for rooting ..it's of course turned into much more but I'd say it is a good reason. read through the root for dummies thread and make sure you know what you are getting into
it's more than just "rooting"
I have read into Myn's warm two point two rom. I have a few questions though. So if I download this rom do I also need to download or flash a kernel? Also in the xda webpage for myns warm rom it says that you can download other stuff for it but do I need to download these items before I install the rom or does it matter?
Sorry but I have another NOOB question but it says to put my ROM into the ROOT of my phone on the sd card. The problem is there is no file that says ROOT. Or is root something else? Where do I put the ROM file?
I got most everything working for myns warm 2.2 but for some reason my internet app is really slow and takes forever to load pages. It is not my connection speed because my 4g signal is great and even when I switched to wifi it still did the same thing. is there a fix for this?
