Would love to know
im using reppards 7.1 rom i have windows 7 i tried to use the portable hotspot and i do get a connection but metro pcs doesnt allow it it opens up a terms of service page and the tethering isnt working for me, would you know how to fix this possibly?
With a rooted phone, you can download the app called Wireless Tether for Root Users, by Muller, Lemons, Buxton.
As far as I know it only makes your phone into a wifi access point and uses the data network for regular internet traffic directed to whatever is connected to it.
Theres a free app called foxfi its for non rooted users so that it bypasses the terms of contract b/s, it should work just fine for your purpose.
lmaoo im rooted tho ;[
Im sure it will work on your phone just the same. Also easy wifi app might work.
There have been a few threads here about Metro and tethering. I don't have the links, but if you search on it, you should be able to find 'em. Basically, if you are using Windows and IE, you will get blocked. I don't know about Windows and Firefox. If you use Mac and Safari you can get through, and Linux with Firefox will let you through also.
im on windows 7 and i tried chrome/firefox all to no avail
Tethering has nothing to do with the easy wifi app...
All easy wifi does is connect your phone to routers that have no passwords...
Noob here. I have droidVPN installed. Would that allow me to bypass the ToS crap?
Alright bro i downloaded the app from the market and i got it to tether to my laptop now the problem was is when it tried to open a internet page it said "Per the Terms and Conditions of Service, Tethering / Mobile Hotspot is not currently supported.
Please visit www.metropcs.com/terms for terms and conditions of service." is there anyway to bypass this?
Wireless Tether for Root users
Try Foxfi its free from google play.
