Left Coast DJ
I'm an Android noob. And I'd love to root my TBolt, primarily to get rid of the bloatware. But is there a simple root process available or in the pipeline yet?
Not yet but in the pipeline. Maybe another week or so?I'm an Android noob. And I'd love to root my TBolt, primarily to get rid of the bloatware. But is there a simple root process available or in the pipeline yet?
It is kind of scary though.The root process IS simple. It's just time-consuming.
If this is your first time rooting, why not do it this way and actually learn what's going on, instead of just pressing a button?
http://androidforums.com/thunderbol...t-your-thunderbolt-but-adb-confusing-you.html
Full disclosure: Although I know how to use ADB, I'm waiting for Unrevoked to release a 1-click rooting method for stock software that doesn't require downloading almost 1 GB of files, downgrading software, applying expoits, and then upgrading software. For me, it's just not worth the hassle to remove bloat, especially since there are not a lot of custom ROMs/kernels available yet.
this.....I really want to back up some things then wipe and restart fresh with no bloatGoing to agree with you on that whole thing. I know ADB, used the heck out of it with my OG Droid, so I'm very comfortable with it. However I'm waiting for the easier method. Hopefully one that will not wipe the whole device so I can save the current setup I have with nandroid...![]()
+1 I'm not familiar with ADB, but I'm pretty sure I could figure this out. I'm trying to hold out for an easier method, but I'm very tempted to try it now and remove all this bloat and sense
Once adb sees the phone it's a matter of typing the exact commands or even copying and pasting the commands.
Then can we assume it won't be too difficult for XDA or other(s) to comprise a 1-click solution that automates this process?
The current method also requires downloading an RUU than the exploits work on. Unfortunately, these exploits don't worked on the shipped RUU.
Your statement pretty much sums my situation.
If I do end up rooting the old fashioned way, will one-click unroot still be an option for me, or will one-click not be able to unroot because I didn't use that program to root it?
Also, is the rooted rom identical to the stock rom with sense ui and bloatware, or was it trimmed down?
Thanks,
-Tom
Thanks,
-Tom
Not so. It's completely stock, you will need to remove the bloat yourself.....
The rooted ROM still has sense and the only thing different is it's newer firmware than what the stock thunderbolts shipped with (you won't even notice a difference) and all the bloat has been stripped, ie: rock band, amazon, city id, etc.
