tbdbuckeyeitl
Member
Is your red camera button loose. Mine wiggles and if you hold it and move it it will go up and down left and right. My other buttons are solid. Is your camera buttons loose. Is this normal. Thanks
Oh, I don't mean that the fact that it wiggles side to side is because of it being a two-stage button. But it's going to have a softer initial depression than other buttons because it's two-stage - which can contribute to its feeling of being wiggly (when added to the side-to-side movement).
It's definitely not a strongly built button - it appears that the button itself is just a small mechanism in the middle of the button, on which the button cover is free to rock back and forth (rather than the mechanism supporting the entire button). Maybe not a good design - but as I said, I will judge it harshly if it breaks, for now it serves its purpose.
Perfect timing as mine came off totally today as I was switching cases. Freaked me out as I had to search for it. FYI the camera (stock app) can NOT be focused or activated without the red bar. Fortunately I found it. It has two pegs that fit into holes on the switch. I probably should have dropped a tiny bit of super glue in there. Will do that if it happens again.
.Really? You must be the pride of your family. I would have taken a picture of the red bar but MY X's CAMERA WOULD NOT WORK WITHOUT IT. And yes I switched from EVO to X. You'll take it back after proof?? WTH would I bother to make this up? IOW who is the real troll?
First off, fix your profile to the X so you won't be mistaken as a troll!
Second, you don't own a point and shoot camera, web cam? if you don't then Ill take back the show pic part.
Third, WHO IN THEIR RITE MIND THAT REALLY OWNS A MOTOROLA DROID X PUT SUPER GLUE TO REATTACH A DESIGN FLAWED BUTTON AND VOID THEIR WARRANTY.
Fourth, Im not the pride of my family my wife and sons are! atleast to me.
PS... If anyone else has had this problem please post your concerns so we can all get properly informed of this problem. TY
