Root Issue with using my phone, as a phone. (EVO running CM7 nightlies)
MusicAddict
Member
I have 2 little issues with my EVO/CM7 I'm hoping someone can help with.
  • I cannot set Google Voice as my default voicemail handler. Settings->Call Settings->Voicemail service Only shows "My carrier"
  • I have to hit "1" every time someone calls me to accept the call. Am I missing a security setting somewhere?
Thanx
Thanx
moved you to the rooting section.
what about clearing cache? done a battery pull? have you tried to reflash?
+1.
When you reflash, if you need to do that, only wipe the cache partition and dalvik cache. Then flash the Rom. This way you won't loose all of your settings etc. ;)
Make sure its the exact same Rom and nightly version, or you will get borked.
Nandroid always of course. :)
