Help it was bound to happen: low memory warning!
Hi all..
I kept getting the LOW SPACE message on my EVO no matter how many apps I deleted. Then I found the issue was with my FACEBOOK app. Try either deleting FB or clearing the cache (go into SETTINGS, then MANAGE APPLICATIONS, then FACEBOOK, then clear cache). The issue went away IMMEDIATELY and only returned when I signed back onto FB! (so you must clear the cache every time you sign off FB, and you'll have to re-enter your user name and password each time you sign back on to FB).
For me it was the FACEBOOK app. The second I cleared the cache on this app, my low space warning disappeared. (SETTINGS.. MANAGE APPLICATIONS.. FACEBOOK.. CLEAR CACHE). By clearing the cache, it deletes your stored username and password, so you'll have to re-enter that the next time you sign onto FB. But at least the app will no longer be running in the background, eating up all your memory!
move more apps to your SD card using CM7 or titanium backup (both need root, but can get temp root using z4root)
