ral
Android Expert
With vos-2 my phone is unstable, i try different frequency but always the same, now i'm on vos-1 and everything is fine..
Thanks. I don't understand though, VOS-2 has more conservative, more stable settings
Not sure I understand... you mean flash ARHD then flash r28? Or you mean better to just stick with ARHD or similar sense rom?
If flashing to ARHD first might help me run r28 I'll give it a shot. If you mean stick with a sense rom, I'd rather just stick to r23 I think.
Ok, I solved my problem, I have flashed my old rom (seraphic GB), opened Maps and activated GPS (yes it was back :fingers-crossed, waited for a fix and then reflash to R28. Then my GPS is now working correctly under JB :victory:
Thanks. I don't understand though, VOS-2 has more conservative, more stable settings![]()
20 builds... but I really don't see all that much change.
Chrome is still buggy (but there is only one DHD ROM I now of where Chrome is not buggy). HW overlay still needs to be disabled. I get a lot of wake time when the screen is off. Feels like what I remember of R8. I don't know if it is faster than R8. It feels about as fast as aospX.
Other than that, everything seems to be working fine. A bit disappointing. I get the impression RB is synching it with the latest CM10 release... not sure which one. The latest CM10 release is probably being updated to fix bugs on a different device.
But it has been a long time since I used R8... what are the tangible improvements over earlier versions of JellyTime?
But if you can run the lower voltages, it is better. If all is good, leave it as it is. Don't mess with it just so we find out why there was a problem![]()
can you fix that?
I've played with sense ROMs, but what other vanilla android 4.1 options are there that rival jellytime?
The only things wrong with r23 that im aware of are that clock crashes if you use countdown timer and that GPS is occasionally a little unreliable (though still better than stock!). R24 and up have added some polish but more bugs/less stability based on my experience (which may not be typical).
DHD is old now... devas may soon move on to more devices and rightly so.
Found this on XDA this morning on the GPS issue:
aospX. It is a fully working ICS AOSP ROM. The headset buttons work. Chrome works on it as well as it does on a Galaxy Nexus. Not much awake time when the screen is off.
Bugs. So far Edomondo Sports Tracker is buggy on it.
Is there a catch. Yes. It is based on the older 2.x kernel used on Gingerbread, patched to be compatible with Ice Cream Sandwich. Not certain what the long term implications of this with new apps are.
Every two weeks or so I go back to this ROM when Sense gets boring... Thank I suffer Sense withdrawal and go back![]()
It seems to be limited to some devices. Our DHD's are identical specifications wise but sometimes different components are used. With the camera, some phones have a Samsung sensor others have a Omnivision sensor. Hence, the incompatibility of some phones with DHD ROM's.
When the 720p video issue on the camera was fixed it worked first on the Samsung sensor, and an Omnivision fix came a few days later.
existz with his aospX ROM keeps a detailed bug tracker and tries to squah each issue, even if his phone is not suffering on the issue. But he has been working on this project since January 24, 2012.
Depending on who you ask it only became daily driver ready in July or August 2012, after 6 or 7 months in development.
JellyTime is only 4 months old, so it would take time before all the bugs are fixed.
The reality is that Randomblame and Synergye will like move unto Android 4.2 before 4.1 is done.
Looking at the change logs and user feedback R24 looks like it might be the most stable, with the builds after that focused on bringing in Android 4.2 features to 4.1.2.
No dice, same problem. Also tried flashing the faster gps fix zip, no joy there either. I've also been playing with PACman 18, same problem there so I'm guessing it might be a CM10 issue...?
The gps antenna is located on the back of the cover where the LED flash is; you could try pressing on this to see if it picks up satellites quicker. See this thread for ideas how to fix it ... http://forum.xda-developers.com/showthread.php?t=1318892 ...
HTH
Dave
HTH
Dave
