Root Juice defender
p-bOt
Android Expert
Just got juice defender ultimate...what now?? Lol.
What settings have been the best for those of you who have used the app??
I personally don't use it that app drains my battery
Yeah I've had it once before and I uninstalled in a grand total of 3 hours lol...too complicated. Just thought I would give it a shot again since i bought it lol
absolutely!! Technically couldn't you just send me a backup? Lol...or you could just post them for everyone...probably a better idea lol
Keep in mind I dont use wifi or bluetooth stuff so my settings are adjusted accordingly.
Profile - aggressive setting and then advanced
Controls Tab
-Mobile data enabled
-wifi enabled
-auto sync disabled
-keep enabled - neither
-bluetooth-disabled
-timeout-disabled
-brightness-disabled
Schedules tab
Schedule-enabled
freq.-15m
duration-15s
controls-custom-data
night-disabled
peak-disabled
weekend-disabled
Triggers Tab
Battery-enabled
threshold-5%
Charger-neither
screen-enabled
options-ignore on low battery
traffic-enabled
traffic thresh-normal-30s
apps-disabled (although this can come in handy if you have a lot of apps that use internet connections)
Location-disabled
I just used juice defender ultimate to fix my CPU governor problem...you can set a governor in juice defender and it actually sticks!!! :D
personally i love JD Ultimate. ive been using it for months
to me personally, the only downside after tweaking it a lil bit, is that it takes a few seconds for radios to turn on when you turn on/unlock your phone. sometimes i gotta wait a few secs for wifi/4g to turn on, which can be a TINY bit annoying at certain times.
other than that, my battery life has went waaaay up, and i can work double shifts without running out of juice with stock battery. woooo
I use JD and really thetwo things that make the biggest difference is wifi and data off when the screen is off. I can get two days out of it with light use with just that option.
My data cuts on as soon as I unlock the screen. No hesitation at all. That's strange yours takes a min.
Does this seem odd to anyone?? Is juice defender keeping my phone awake when the screen is off??
No it's not jd.
I had this problem several times and could not figure it out to save my life. It went away so i quit worrying about it.
It's not jd though
No it's not jd.
It's not jd though
that's weird...i haven't really payed that much attention to it but I really don't think it started doing that until I started using jd...I guess we will see if goes away.
Trust me. You can go back and check the threads i started over this issue. It's not jd.
I literally Sat down and uninstalled every app even system apps one by one trying to find the problem. Nothing.
Each time I've had the issue i flash my ROM again and it goes away.
An app called better battery stats is what i was using to watch if my phone would deep sleep or not. It's not on market but i posted on here somewhere. It's a great app, very detailed.
But you gotta remember, if you have sync enabled or if you have your phone set to update every so often it's going to wake the phone up even know the screen is off.
and honestly your graph looks close to normal. It's when the phone stays awake constantly when the screen is off that becomes a problem and that's what i was dealing with. Go back and find my threads and you will see, i posted screens and stuff.
alright thanks man. I'm just nit picking lol...I was iffy about using jd anyways lol
No one nit picks more than me so i understand. That ish drove me insane. But jd is the best battery saving app hands down. It takes a few days for it to learn your habits but once it settles down and you see how much you save, you'll never not go without it ever again. ;)
haha alright ill give it a few days :) in the mean time im gonna disable the sync schedule and see if that keeps my phone from waking so much
I didnt see any improvements on my DX and seen worse battery life on my wifes Admire running JD. ;)
I cant go with out it. If I reboot my phone it doesn't cut on, Ill notice around lunch time cause my phone will be 50% and i havent even used it. haha
I've used it on the Ascend, Galaxy Indulge and the Esteem and I can't speak good enough things about. But this is only the ultimate version. The paid version didn't do much for me. ;)
