Root [KERNEL][DEV] Plague for LG Optimus M+ LGMS695
PlayfulGod
Extreme Android User
USE AT YOUR OWN RISK!!!! I am not responsible for anything you do to your phone!
This is built from LG src for the LGMS695. This needs testing before I can release into the wild, so anyone brave enough to risk making your new phone into a doorstop hit me up on irc. You will need to be rooted and have CWM installed. ;)
The IRC channel is located at:
irc.irondust.net #hitsquad
Or connect thru webchat: IronDust Web IRC
Features
  • Overclocking - Up to 1.5Ghz (these settings are subject to change depending on how the majority can handle the speeds.) NOTE: ALL Phones may not be able to handle max settings!!!
  • rooted (as in adb gets # automatically ;))
  • Smartass2 governor added
  • Lagfree governor added
  • SIO scheduler added
The Goods
Plague-LGMS695-Beta.zip 4.13 MB
OK Playful god and Shabby Penguins hooked on Macronics, I just bricked my LGMS695 I bought May 9th. Now I have one left. I am ready to ROOT and FLASH CWM. Let me now about trying out a ROM for you or anything else. I can do for you. I have ADB and QtADB, I think I can handle it!!
OH noooo!
Not one single post about the kernel, which is the topic for discussion in this thread.
Ok. I called it testKernalfromHell. As soon as get a good recovery boot and nandroid b/u's, I will give it a go! THX!
Features
  • Overclocking
Thats it for now.
Will this kernel allow wifi tether? My friend is wanting to get his rooted and use wifi tether. i tried the wifi tether app from play store and it said kernel wouldnt allow it to tether so basically im trying to find out if stock kernel will allow tether through the wifi tether app or does there need to be a kernel released before we can tether....
quechon was pose to be testing it earlier tonight but he poofed b4 reporting back to me on it lol
I'm still available for testing I just need to know how to get to recovery with hard keys but I didn't poof I had to pick up my kid from school
Power + vol down until the led lights come on, release and hold the home button.
*Poof*
*Poof*
That doesn't work for me maybe I'm doing it wrong but until I learn how to get to cwm that way I won't do it I just got this phone every time I try it just reboot
linkage for the Beta in the OP. Initial testing has been good. Only issues reported thus far is broken wifi, hence the beta tag and feedback needed. May be fixed in this build ;)
Just flashed plague on my moms esteem haha she is amazed. .is it possible to merge the wifi modules into the beta and rezip? Or do they need to be recompiled?
Testers are current trying various things. Thing is only 2 of the 5 modules are getting compiled with the kernel src. And the wlan.ko is symlinked to the ones in /volan and wont zip if they are included lol.
I reverted the kernel's version prefix to what it is stock so it wouldnt matter, but thats not seem to fixed the issue yet either. We are working on it tho ;)
I clicked the download link... but it doesn't appear to be available anymore... I am really interested in this kernel and am glad other people have taken the time to make this phone better... can't wait to download the kernel when its back online
