Root [KERNEL][LG870] Freedom Kernel *Updated 9/14/14*
Done! Exactly as u said. Thanks again!
No problem, Thank you! ;)
Kernel Updated!
New added features:
  • Updated to ZV5 bootloader
  • Frandom built in for increased speed - details
  • Added SmartassV2 governor
  • Added Intellidemand governor
  • Added Superbad governor
  • Enabled Conservative governor
  • Init.d support is now built in and no longer needs sysinit
This has been loki'd with the new loki update and will also upgrade your bootloader to ZV5.
Please do not include this kernel in any roms. Thanks
Bumping this post to page 3 for those that may have missed it.
So no work around with init.d. ok. Thanks anyways wish i knew what the problem was
Init.d is not for syncing gaming controllers. Search the play store for an app or google for a mod to sync your controller. I don't own this phone so I can't help you with that.
Why dosent this have over clock support also does it have ram.swap. it trying to figure out how to.get the main fetures of a rom with out installing. One
Why dosent this have over coock support also does it have ram.swap. it trying to figure out how to.get the main fetures of a rom with out installing. One
All features of this kernel are listed in the first post. Just read the feature list and what you see there is what it has.
Kernel Updated
CHANGES:
  • Added android TRIM - details
  • Speed tweak for Frandom
TOTAL ADDED FEATURES:
  • Allows removal of "any" app without bricking
  • Unsecured
  • Android TRIM - details
  • SmartassV2 governor
  • Intellidemand governor
  • Superbad governor
  • Conservative governor
  • Init.d support - details
NOTE:
I do not own an F7 so please keep that in mind when you ask any questions.
I won't be adding faux since I don't have this phone. Viper4Android audio effects works no matter what kernel you have installed and is really good.
If you guys like Viper4Android start a new thread for it, but please don't troubleshoot it in this thread.
so, I installed the zip after a fresh zip of Simplicity 2.0. I can see the test00 and everything, but I don't see Intelli-active and such in the CPU kernel.
Maybe I've gotten something wrong, but i flashed the zip, and nothing seems different. Is there no app to this, or settings anywhere to change CPU settings?
Umm intelliactive is not in this kernel. Have a look at the feature list for what's available in the kernel.
To change settings you can use an app like SetCPU. I find this app to be most reliable.
https://play.google.com/store/apps/details?id=com.mhuang.overclocking
Sorry, got confused.
Also, with TRIM and the other features, are they run automatically, without needing to do anything extra?
And thanks!
No problem. ;)
Yeah it's all automatic and I also set the interactive governor as the default. If you want to change to another governor you can use the app I mentioned in my previous post.
No problem. ;)
Which is best for conserving battery for average use. Just Facebook messaging and texting? I'm not too spot on with governors.
For a good balance of battery and performance I find interactive or intellidemand govs best. If you don't care about performance and just want battery to last long then you can use conservative gov, but this gov is so focused on battery that it'll cause lag.
