So here's a device status update:
I installed the above kernel, as you all will remember, and every thing was going gravy smooth so I decided I to try my luck with a custom theme flashed to the stock ROM.
Without toooo many details, I'll say that the theme turned out to be slightly off in regards to the status bar icons. I decided that instead of attempting to fix the situation, simply because I know nothing of theming & knew that I would be in too deep, I attempted a TWRP restore from a backup that was just performed 2 days prior...just to see if the freshly installed TWRP was functioning correctly.
The damn thing FAILED!
On the first attempt the MD5 verification didn't jive (...and here is where I should have stopped & rebooted...). But no! I toggle MD5 verification then proceed with a further attempt to restore. Restore process proceeds with a system wipe, furthermore & furthermore to about 80% then fails again.
Here's where I panicked because all my poor lil droid will do now is boot to TWRP recovery....so...here's where things get fuzzy, but I believe there was a factory reset, complete with another complete system wipe. I was button-pushing like a fiend, I am embarrassed to say.
I finally get things square again by a sideway load, not a common "sideload" but what I call "sideways".
I did it by way of downloading a Project Butter Rush variant, the v1 I believe, to my other Android's SD then swapping cards between phones to flash the PBR ROM via TWRP.
Luckily TWRP did not fail this time. My Rush is now functional again.
Now my first question is this: Why did the MD5 sum verification fail on restore? Or rather, why would it fail? I chose to compress on backup, could that possibly be an issue? Also, I moved the backup files to & from my extSDcard back to the internal...I have but a 2G extSD so as memory gets tight, my files travel.
Next question: This ROM is running fine, by the way, but the kernel has less RAM, 612. I want 639 again. So, do I need to run the 90zram script prior to flash or can I just flash the A-kernel v3.3-r9-fix sans script & still be compatible?
Any thoughts are appreciated.
