Root [KERNEL][MS870][LOKI] Freedom Kernel Overclocked
GameTheory
Android Expert
When There's Freedom, There's Potential...
Freedom Kernel
Added Features:
  • Allows removal of "any" app without bricking
  • ADB rooted
  • 1.8ghz overclock
  • Interactive governor
  • conservative governor
  • SmartassV2 governor
  • Intellidemand governor
  • Superbad governor
  • Init.D support - details
Change Log:
12/22/2013
--1.8ghz overclock
--conservative governor
--SmartassV2 governor
--Intellidemand governor
--Superbad governor
--Init.D support
7/21/2013
--Adjusted clock to 1.674ghz
--3 step overclock
--Adjusted voltage
--This kernel now works for everyone
7/19/2013
--Initial release for testing
You know the drill, so here's the warning... You're flashing this at your own risk and I'm not responsible.
Instructions:
  • Wipe Cache in Recovery
  • Then Flash Zip
Download
*Important*
Make sure to have another kernel on your sd card in case your phone bootloops due to this kernel's voltage being too low for your phone. You can use the button combo to get into recovery to flash the backup kernel in event of bootloop.
Thanks to Bliss for loki to bypass locked bootloader.
If you like my work and want to show some appreciation, please click the thanks button. :)
Thank you all.
Enjoy! ;)
What do you think we should be clocked at that's set on boot for a good speed? Right now I'm clocked at 1.674 set at boot
GT, I keep getting "secure boot error" and phone turns off after flashing and restart. :confused: Just reflashed your modded unsecured kernel to get my phone to boot.
I re downloaded file. Same result. I had no problem flashing GT other kernel. Phone will not boot, LG logo secure boot error and shuts off. Have to go into recovery. I guess my phone doesn't want to be OC'd. I just flash this kernel right? I don't have to wipe anything?
Yea I get same error. Secure bopt error then shuts off. I love it though. Thanks for all the work you put in.
I tried true recovery and 2nd init.
And downloaded twice with different browsers.
Got security error, I'll wait for the new ROM GT, if it is still coming. Looks like Slime made a bad joke and posted a fake thread for what was to be your new ROM
