I think both, and stock too, cause I am pretty sure ticker got it to work that way in CM7 because that is how the internal hardware is supposed to work. I am not sure of MIUI, but it is based off the CM7 code for parts of it, possibly this part?Do MIUI have trickle charging, or just CM7?
This phone's internal hardware switches to a much lower-output charge at 90% and turns the light green, even though it's not entirely full. If the stats are wrong it will enter this mode with the battery being WELL short of actually being full, and require many hours of additional charging (in some cases as long as overnight!) before it reaches an actual full charge. This is actually a good thing rather than a bad one (contrary to some people's views) as overcharging lithium cells both damages them and can cause overheating (which again can lead to fires!); I like how the Triumph manages the battery although it can easily lead to a situation where you think you have 100% when you really don't, especially if you're swapping batteries or ROMs around, and that in turn leads to surprises when the phone shuts down while you think it has plenty of battery left.
If I want to switch from mock to speed demon do I need to wipe anything else besides the delvik.
I had decided to wait on Isaac but it seems he have stopped development...
I think you(and me too...) need to recalibrate battery, you could also try to reduce each stock value by 75, in incredicontrol.
