TheOCv1-wip-4.zip
- Added I/O schedulers cfq, vr, and sio. Go ahead and try them out if you want. I was able to set them using No Frills CPU control -- available free on the market. I tested running lots of quadrants and deadline still seemed the fastest on average than the rest but ymmv.
-Added SVS for voltage control. You can set the voltage in one of 3 ways:
1. manually edit the vdd_levels file in /sys/devices/system/cpu/cpu0/cpufreq/ using either adb or a file manager.
2. Set up a script and put it into init.d to set the file upon boot.
3. The simplest way - use the Incredicontrol app to set the voltage. You can read about it from on xda and a download link is also provided there or download it from the Market:
[MOD] IncrediControl - Easy GUI Undervolting - xda-developers
Thanks to b_randon14 and chad0989 who's posts and links and info helped a lot as well as the million posts from everyone that I read over the last few days...
- I'm using the following undervolt table on my phone in Incredicontrol and it seems pretty stable; try out your own settings and see. The higher frequencies > 1.7 GHz would not undervolt for me without locking up and rebooting but your phone might fare better. I suggest that you DO NOT APPLY the settings on Boot until you are sure your phone is stable.
<snip>
