. Let me know how it goes, or just post in the main thread, there.Did you make sure to connect to a few satellites while on a Sense ROM, then leave it on before shutting down to restore Kings? Silly question, but did you try actually going outside?
That's definitely strange. What app were you using? Did you try an actual GPS test app?
Are you connected to wifi inside? If so it is using the network
I found today that even when GPS test shows no satellites being used mine was still working fine
Definitely could be specific to that app. I want to say I have seen other posts from folks having issues with it. What is so special about it I have only used Google nav
