Root Lag Reduction
@zeest: no, I used the alpha that we have. during testing stages for my guide.
@plasticarmyman: download rc2. I'm absolutely sure it works.
as decad3nce explains (his is the google plus thread) it is keeping your cpu up higher since it has to run stuff every so often, which means your cpu isnt sleeping or in a low powered state. you would get the same performance jump by using setcpu and changing your governor to performance. you drain more battery but you get a perkier phone
well my bad...i will edit the OP...i do suggest disabling it and any init.d scripts you may have installed before uninstalling the app...
PLEASE for the love of God, do NOT Install this! Your Motion will start to glitch out and the screen will turn purple. I figured out that it is because of this. Please, save your phone from what looks to be irreversible damage........
a little over dramatic, but yeah. don't use this if you've all ready modded your phone. leads to some baaaaaad stuff,
didn't happen to me...at all..but i noticed that you had other mods installed that i do not....so it conflicts with those...
I noticed this after doing a bunch of benchmark tests with this enabled on my optimus m.
What does the "Adrenaline Injector" do that PmR doesn't?
And what's all this lag I'm hearing about? My Motion runs very smoothly, not sure what the fuss is.
All this does is drain more battery so go ahead and try it it doesnt make a difference on the motion
PMR has a lot of functions pertaining to the necessities of a smart phone (battery mods, software and apps, CPU modifications etc) the adrenaline booster is basically just a shot for the system to wake up. It has init.d tweaks for the early riser who has a lot of startup apps like messengers, down loaders, twitter/Facebook/xanga whatever. It also has a swappiness tweak that can let you use some of your internal or external memory as backup ROM for super memory hogging games. My favorite tweaks are your basic build prop tweaks, all the basics like hardware acceleration, scroll speed, 1x/2g/evdo/4g buffer and a bevvy of other mods.
Zimm is right though, it does drain battery. That only happens when you have doubles and triples of the same tweak in your build.prop though.
So for everyone's sake, the adrenaline shot is only meant as the first stop for someone using a new ROM and is to lazy to manually add in the lines. (Like myself ;D)
Try using a down loader to download a 500 mb torrent, lg motion seemed like pure irony in that timeframe.
