Help LauncherPro Dock Question
802kk681
Feel kind of stupid to ask newb questions again...
Just rooted my phone and got the homescreen set up w/ LauncherPro Plus...but the phone icon and the contacts icon in my dock are just icons...and don't do anything when I press them.
I tried to change the "Swipe gesture action" and the "Change Shortcut" but on the shortcuts there is no choice for either contacts or phone.
Help?!! thanks!!
I do love the dock. Not to thread jack but I only have the free version not the Plus version. In the free version I get 3 docks [15apps total] does the paid Plus version have additional docks?
I agree, it looks so much sleeker than the TW one. And no, the max docks is still three with the Plus version.
Ok, yeah I know some the widgets with the Plus version are tempting. But to this point I've only bought and paid for one app thru the market. Usually the free/lite versions are good enough for me. LPPlus might be the second one I purchase and beautiful widgets might then be the third
I keep hearing about Beautiful Widgets, should check it out.. Honestly, I don't use any of the LP+ widgets. The widget-resizing will be nice if I come across needing it, but for the most part it was to support the dev. It's only a couple bucks, afterall.
Agreed. I have not been as supportive of the devs as I probably should have been/be :o
I am having the same issue but only with my contacts and there is no option in "change shortcut" for contacts...?
I'm sure. There is a "contact" but you can only choose one. I tried uninstalling and reinstall and same problem.
Oh my bad. I miss understood. You want to add contacts right? Its under applications... Unless I'm misunderstanding you again. But yeah if you wanna add the icon for all you're contacts its under applications
I believe you are kind sir! Lol
I have the stock launcher pro dock. When I click the spot for contacts it says something about nothing being there... So I long press and click add shortcut and there is no contacts there.
I don't... are you one hundred percent sure that you open the applications list and select the contacts app?
yes 100%
hold down dock icon
edit dock shortcut
change shortcut
applications
choose "orange "contacts list icon
choose icon- default or LP or custom
now it should work.
yes 100%
hold down dock icon
edit dock shortcut
change shortcut
applications
now it should work.
Haha no I'm asking the other guy if he's 100% sure that's what he's doing.
You gentlemen, are my heroes. I figured that choosing applications would just make the app drawer open for that dock icon. But I clicked applications and it brought all of them up for me to choose. Many thanks!
Yeah until you know something/anything its like :confused: and then once you know its like :rolleyes:.
Glad you're up and running iClark
