Here is something you newer footers may not have known you could do with root, change the LCD density to make your phone screen appear a higher resolution.
It is a simple hack of the build.prop. Using root explorer out are looking for the line "ro.sf.lcd_density=240" you will then change the 240 to a lower number. Keep in mind this may affect how some apps look in a bad way.
When doing this hack please do not drastically change the density at once, go down by steps of 20 or less per reboot so you do not have issues upon boot.
I personally like 185 for AOSP roms using launcher pro and I think 209 or 210 is best for sense roms but I am an AOSP guy so I could be wrong. I am attaching 3 screenshots of unedited build.prop files and 1 screenshot of an edited one.
Unedited LTB
Unedited OMFGB
Unedited Gingeritis
Edited LTB
Unedited LTB
Unedited OMFGB
Unedited Gingeritis
Edited LTB
, or would that be someone else on the forums...?
<- perhaps I should have read more...
