That is really low, the lowest I EVER got was like ~950
I would get System panel, kill processes that aren't needed and then run the test again.
Maybe it's constantly looking for the apps we removed?
I am going to remove a bunch apps later tonight and try it out. But I am not going to keep a bunch of bloatware on my phone just to have my score show up higher.
And if that is the case than this is a pretty crappy test.
I've removed countless bloatware. It is not correlated to low scores on quadrant.
I don't know but you aren't alone.
This is a testing release, not final.
Try reinstalling it, but first, wipe your boot partition from clockwork.
I've gotten as high as 1314 in Quadrant. Something def seems wrong if you are getting scores under 1000.
