zeroboy1020
i deleted some system apps i tryed putting them back on. i turn my phone off and back on and now my lg ally is boot looping and i cant go into recovery. is there anything i can do to fix it or am i screwed?
If you didn't do a backup (which i'm not sure why you wouldn't), then you might be forced to do one of the procedures to go back to a completely stock ROM. Frisco posted a link above with the steps to follow. Just make sure next time you do a backup. It's such a simple thing to do and can eliminate so many potential problems.
Just a note: Do not remove Launcher2.apk or rename it at all. It is the default Android Home launcher and without it you would not be able to boot into android. Unless you had a third party launcher installed. (Don't quote me on the last sentence.)
