Help LG OPTIMUS M+, NEEDS A (LG MS695 lgnpst dll), firmware download!?
Can any of you fine developers please find some time to help this phone out.
I hope one of you take an intrest in this device.
thanks guys, irishman
It is not as easy as it sounds. A developer first has to have the phone. Then an backup in case the first one gets bricked.
if you brick a phone in these days then you deserve it. i have done some fairly risky stuff and have always been able to recover, closest i ever came to thinking i was stuck is when i forced an engineering bootloader on my photon to see if it would be unlocked and have 4g... took me about 2 hours to get back to stock.
that being said that dll is useless with lgnpst, you need a tot file to go along with it and the only place that gets those are phone service centers and lg
If someone who worked for metro would share it, that would be nice, and it could also be a .bin file I believe.
hello, name of orginal firmware ms695: MS695ZV4_11.S4_11.P3027.cab
you can download firmware with this tool:
need net framwork 4.0
see : hxxp://forum.xda-developers.com/showthread.php?t=1073827
hxxp://dl.xda-developers.com/attachdl/8a21b87f7e6ddf3c58ec8d99cb9dad9a/4fca6563/5/9/2/8/7/1/Original_LG_Firmware.zip
set type: ms695
set serial from your phone:................
or this serial number from over ms695 : 203KPAE0114120
extract cab and you find :
MS695_WD_1_0_0_2.dll
MS695ZV4_11.S4_11.P3027.wdb
MS695ZV4_11.S4_11.P3027.wdh
you can extract wdb-dll file to bin file with lg extractor 0.2.1 :-)
hxxp://dl.xda-developers.com/attachdl/b4175812f3ac119799c18c4769ca623c/4fc9ee2b/9/7/5/9/3/3/LGExtract-0.2.1.7z
see : Application for download Original LG Firmware - xda-developers
http://dl.xda-developers.com/attach...4fca6563/5/9/2/8/7/1/Original_LG_Firmware.zip
set type: ms695
http://dl.xda-developers.com/attach...a623c/4fc9ee2b/9/7/5/9/3/3/LGExtract-0.2.1.7z
fixed links
Hello, I search for files: lghome.apk and lghome.odex from the directory: / system / apps / lghome.apk .........
This is the launcher
could someone please upload the one for me?
Videojo: Yours is a totally different problem and would get the thread off topic. Start a new thread by clicking on the New Thread button on the TOP of all the threads. It will also open up another box that will give you some similar threads. Look at those before starting a new thread to make sure there is not a thread already about your problem in the Optimus M+ forum.
You will get more members looking at your problem this way.
Thanks.
that unbricking method has worked perfect....until.... I put in the Spc code it says it doesnt support unknown Model type..and also i get another error saying the phone isnt answering to the LGnPST commands...please save my ass one more time guys?
thank you, Irishman
thank you, Irishman
Did you get your SPC from CDMAworkshop?
EDIT: did you register the dll file with reggie.exe?
hxxp://dc615.4shared.com/download/EGAHEOFQ/LGMS695_M3__Android_GB_MS695ZV.zip?tsid=20121031-071007-9bc84bca&dsid=3ohbqa.d517972c391b1b7203aa2835e84988a6
